Author: Subject: earthing
robertst
posted on 17/10/06 at 10:01 AM Reply With Quote
earthing
i was wondering yesterday... might sound like a really silly question but..
the fuel tank has to be earthed to the chassis right?
i was thinking about this in the rare case of lightning striking the car...
Humbug
posted on 17/10/06 at 10:05 AM Reply With Quote
Not sure about "has to" as in legal requirement, but seems like a good idea!. I put one earth wire from a fixing bolt on the aero filler, and one from the sender.
posted on 17/10/06 at 10:34 AM Reply With Quote
interesting question - one I have not come across before.
I find it hard to imagine how you would secure/fit a tank without it being earthed to the chassis - you would need to go out of your way to use rubber pads etc.
Now if the tank was not made of metal,then that would be easier to do.
I doubt you need to worry about lightning; there were stories about sparks when filling from petrol pumps years ago but I dunno if it was a urban myth thing.
posted on 17/10/06 at 10:49 AM Reply With Quote
My ally tank is sat on sponge strips which are stuck to painted chassis rails. The painted tank straps are similarly lined with sponge. This means that the tank is very nicely insulated from the chassis. The fuel level sender has an earth connection, so in theory the tank is earthed (proved by testing with a multi-meter). I'm not planning on adding anything elase to it though.
DavidM
posted on 17/10/06 at 11:57 AM Reply With Quote
Surely your car's seperated from earth by those four big round black rubber things anyway?
Proportion is Everything
DaveFJ
posted on 17/10/06 at 12:22 PM Reply With Quote
I would have to agree... your tank should to be earthed in some way.
Dave
barrie sharp
posted on 17/10/06 at 02:18 PM Reply With Quote
I would think that Lighting will be along soon to explain all, I think thats his job hence the name.
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Mike S
posted on 17/10/06 at 02:46 PM Reply With Quote
The tank needs to be earthed to the chassis so that the fuel sender works.
I have fitted a decent sized earth strap between tank and chassis on my car because the tank is on rubber mounts.
It would in my view, be a bad thing to have a potential difference between the tank and the chassis as this could lead to sparks between the two.
Of course, this would not deal with the issue of the whole car being at a potential to the ground due to friction static charge. This is where you get a belt when you get out of the car and touch the ground.
Mike
There are more horses' asses in this world than there are horses
StevieB
posted on 17/10/06 at 03:09 PM Reply With Quote
It technically shouldn't be an issue due to the whole faraday cage effect you get.
However, most theories can be proved wrong at some point, and I'd imagine you wouldn't want the proving to be while your sat 12 inches from a full tank of fuel that's not earthed!
MkIndy7
posted on 17/10/06 at 04:26 PM Reply With Quote
Another view to throw in the mix....
If you didn't need the earth for the sender wouldn't you be better off with the Ali fuel tank completely isolated from the Chassis,
Then should a stray live (+ve) wire touch it, it wouldn't spark?
tks
posted on 17/10/06 at 04:50 PM Reply With Quote
..fuel tank in the back
you need to earth the tank and the fller neck
because when the rubber build up some voltage it cant crate a spark on the filler neck with the pump filler pistol..
thats where you don´t want a spark where the gas goes in!!
I grinded / welded mig / tigged near the petrol tank with some fuel..
offcourse it was shutdown...
Tks
robertst
posted on 17/10/06 at 05:44 PM Reply With Quote
so an earth strap would do the job then?
i dont really trust on relying only on the sender earth,
to make things clear and safe for everyone, maybe i/we should create a kind of checklist of all earth connections to follow so as not to forget anything at the time of SVA/simply gettting on the car.
i have heard stories about how some garages here forgot to reconnect the engine earth strap after a rebuild, and interesting things happening!
snapper
posted on 17/10/06 at 05:56 PM Reply With Quote
Definately eart the tank and filler you also get static build up when you fill a tank, i checked out the fuelers at wattisham and they connect both the Helo and the tanker to earth to stop static.
As for the 4 rubber things providing protection, it's a soft top so no farrady effect, static is high voltage and can jump gaps, the car has a battery so is a circuit all on its own. If you dont earth the engine etc then the cranking amps have to find somewere to go and that could be up any small wire it can find.
I am going to check all my earths now.
907
I have a nice polished stainless steel chassis.
Like the old Martini advert.....
Any bolt, Any screw, Anywhere.
Paul G
Danozeman
posted on 17/10/06 at 06:03 PM Reply With Quote
MIne is mounted on rubber to stop vibration and insulate it etc. My sender has a plastic base and 2 wires going in so not earthed at all.
Dan
