myeates
posted on 21/10/06 at 03:35 PM |
ballast resistor
hi all i have a standard ignition coil in the garage (been laying around for years) that should be ok for the 1.3 x-flow i have in the car do i have
to have a ballast resistor with it or should it be ok without it fitted. if so what should i fit as finding it hard to find one for the mk1 escort
thanks all
stevebubs
posted on 21/10/06 at 07:45 PM |
I *think* I fitted a 12v MGB coil to my xflow without issues.
flak monkey
posted on 21/10/06 at 08:36 PM |
If you want to not use a ballast resistor, you need to use a 12v coil. If you use a coil designed for use with a ballast resistor without you will end
up burning one side of your points very quickly.
I bought a bosch high energy coil with a ballast resistor (i removed the one from the loom) from ebay for £5.
Sera
http://www.motosera.com
posted on 21/10/06 at 08:46 PM |
Using a ballast resistor coil without the resistor will cause the condensor to fail very quickly which causes the points to burn out. Guess how I
found out about 30 years ago!
posted on 23/10/06 at 09:26 AM |
measure resistonace of primary coil
3 ohm = 12 V coil
1.5 ohm = 9 V coil (ballast).
If you are using 12 V coil, then you don;t waqnt ballast resistor - I've never seen one but believe it looks like a thick wire hidden
mysteriousl in the loom.
posted on 23/10/06 at 10:23 AM |
There were two types of resistor used, a thick grey wire under the wing mount or a ceramic block which looked like a fuse was used on early Transits.
12v is better if you have a choice, less to go wrong.
