Author: Subject: Lucas wiper motor - have I killed it?
chrsgrain
posted on 28/10/06 at 06:47 PM Reply With Quote
Hi all,
was wiring this evening, and got the wipers to work (standard Lucus motor), but slow was fast and fast was slow - so switched the wires round, unfortunately switched round the wrong wires, so had the 'fast' wire onto the 'park' terminal - switched the ignition on, there was a click and the now the thing won't work at all.....
Have I killed it? (fuse is OK) Any suggestions for resuscitation? My thought is the microswitch has been killed... bit disappointed that just switching the wires round wrong has knackered it!
Chris
[Edited on 28/10/06 by chrsgrain]
stevec
posted on 28/10/06 at 08:23 PM Reply With Quote
A\bit obvious but what happens when you put them back, I would have thought ther would have been the blinding flash and funny smell if you had f**ked it
chrsgrain
posted on 28/10/06 at 08:41 PM Reply With Quote
Yep - all back how it should be - but nowt....
It'll be a pig of a job to get the motor out again as well..
Chris
stevec
posted on 28/10/06 at 08:50 PM Reply With Quote
Double check the fuse, or just change it anyway.
Steve.
chrsgrain
posted on 28/10/06 at 08:58 PM Reply With Quote
Steve, you are a wise man - I'd labelled the fuses wrong! The one labelled heater had blown and a quick switch and all is well in wiper land!
I'll go and feel stupid now shall I! Thanks....
Chris
stevec
posted on 28/10/06 at 09:01 PM Reply With Quote
Great stuff,Glad to help.
Steve,
posted on 29/10/06 at 12:05 PM Reply With Quote
I doubt you an kill the motor - it has to be the fuse. the park feature is mysterious in that is supplies power to the switch thatthen goes to the motor until the motors parks. I had fun with blowing fuses when I wired it up wrong in my land rovers - debugged it eventually by using bits of wire from mains cable as a few until I could get my brain around the mysterious wirings.
