Author: Subject: Clifford concept 650
jon_boy
posted on 2/11/06 at 03:00 PM Reply With Quote
At work (at a garage) we had a part ex come in with said alarm on that was going to be traded for a couple of hundred, so i had the alarm out. Its all in working order but basically i could do with the wiring diagram to get it into my car. Any help would be appreciated. Jon
scoey m
Builder
Posts 209
Registered 8/2/06
Member Is Offline
Photo Archive Go!
Building: MNR Vortx r1(sva pass 07 plate yumyum)
posted on 2/11/06 at 07:41 PM Reply With Quote
Hi mate
Had a clifford in my old tin top and most wires are black so unless installed from new with indicating tags i think you will struggle highly
Thats why there so expensive to install and buy
Only help i can give sorry
quadra
posted on 2/11/06 at 08:14 PM Reply With Quote
You could try asking at www.the12volt.com under the car alarms bit. I did for a clifford immobilser and it worked. Owners guides can be found at www.clifford.com/guides/other
Hope that helps.
Cheers Mike
You don't need eyes to see, you need vision!
jon_boy
posted on 2/11/06 at 11:19 PM Reply With Quote
Right. After some gueswork and two fuses i have it basically going. Just want to be fancy and wire it up so i can start my car from indoors etc. Tried the clifford site and it only goes up to the 600 series. but thanks for the replies people!!
jon_boy
posted on 3/11/06 at 10:30 AM Reply With Quote
And we have lift off. If anyone ever needs help with one....
