Rudy
posted on 4/11/06 at 12:46 PM |
Zetec alternator brackets
Hi friends,
Does anyone have a project or any foto about making alternator brackets on zetec engine? Or does anybody knows where I can buy alternators bracket
Original mondeo bracket is too large to fit on my Tiger Avon.
Thankyou
Sorry about my English
Danozeman
posted on 4/11/06 at 12:55 PM |
Is it a silver top mate? All i did for mine was get a bit of plate and weld some legs on in the appropriate place. Ill try and get some piccies
later.
[Edited on 4/11/06 by Danozeman]
Dan
givemethebighammer
posted on 4/11/06 at 01:02 PM |
Siert's design worked for me
http://home.tiscali.nl/~svos/alternator.html
Rudy
posted on 4/11/06 at 01:15 PM |
Yes it is a 1.8 silver top
lsdweb
posted on 4/11/06 at 02:01 PM |
Rudy
I bought mine from Tiger - it was pretty crap and I wished I done it myself.
Photo here
Regards
Wyn
big_wasa
posted on 4/11/06 at 03:20 PM |
Very easy.
Easy alternator to use is the sierra Dohc as it has a good pulley. The belt you would want is Halfords part Hb925g and comes from many diesel engines
inclueding the ford Galaxy. I have made a couple of set ups like this. Top brackets depend on your induction but Renault 5 arm works well.
big_wasa
posted on 4/11/06 at 03:23 PM |
Renault 5 alternator on a more complicated bracket.
Try and keep it close to the engine or you will end up with problems with clearance with the steering link
big_wasa
posted on 4/11/06 at 03:26 PM |
2nd angle
big_wasa
And third is the Dunnell engines set up
stevebubs
posted on 4/11/06 at 03:39 PM |
standard Mk 2 mondeo setup...including standard tensioner..will fit a silvertop without any alteration.
(note: power steering pump long since removed)
[Edited on 4/11/06 by stevebubs]
Rudy
posted on 6/11/06 at 08:23 PM |
I do not understand why big_wasa have a water pump pulley grooved. I have " slik" pulley. Water pump should run counterclockwise, instead
big_wasa water pump run clockwise.
Did I miss something?
givemethebighammer
posted on 6/11/06 at 08:32 PM |
The 2.0L zetec water pump runs off the back of the belt, hence the smooth pulley. The 1.8L Zetec water pump runs off the grooved side of the belt
hence the grooved pulley. However, it is common for people to fit the 1.8L water pump to the 2.0L engine as it allows you to use a simple triangulated
arrangment with the drive: belt crank > water pump > alternator, and everything still runs the correct direction.
big_wasa
posted on 6/11/06 at 08:37 PM |
Hi Rudy,
Thats easy to explain. If you have 1.8 silver top with a smooth water pump pully then your engine has come from a mondeo. The pump on these runs
backwards compared to the escort/fiesta/orion and is driven by the back of the belt. So in a 7 the fix is to fit the escort waterpump and pulley.
regards warren
edit Doh , must type quicker
[Edited on 6/11/06 by big_wasa]
Rudy
posted on 6/11/06 at 08:39 PM |
Ok I have understand!
Thankyou very much!
