jacko
posted on 8/11/06 at 07:08 PM |
Low fuel warning light
Hi can some one tell me what i need to fit in my fuel tank to make a light work when it gets low with fuel . I dont have a fuel gauge Thankyou Graham
PS were do i buy the bits from
rayward
| posted on 8/11/06 at 09:17 PM |
HI graham.
i was thinking of using one of
These
Ray
RazMan
| posted on 8/11/06 at 10:34 PM |
I used one of those switches (actually a plastic version) in my brake & clutch reservoir - works a treat and dead simple to install.
Just drill a hole in the tank at the desired level and insert the float switch and tighten the nut. Then wire up the switch to a warning light and +ve
feed ..... job done.
Raz
PeterW
| posted on 8/11/06 at 10:56 PM |
I've been racking my brains on how to do a level switch for the SVA !! Wanted remote reservoir, but couldn't find a decent one with a
float in the lid..!
Peter
Jon Ison
| posted on 8/11/06 at 11:07 PM |
Ray, the page as timed out, can you post a part number or page too find the sender unit ?
RazMan
| posted on 9/11/06 at 12:18 AM |
The one I used was stock number 338 9722 and was less than £8
Link
Raz
rayward
| posted on 9/11/06 at 07:55 AM |
DOh!.
part number is 431-8406 ,stainless too
the plastic ones are ok , buti wouldn't risk using one in a fuel tank though!
Ray
flak monkey
| posted on 9/11/06 at 08:08 AM |
Both Nylon and PPS are fuel resistant so they would be fine to use in a fuel tank and both nitrile and viton seals are fuel resistant, so this one
would be fine:
338-9750
Its external mount, so you dont need access to the inside of the tank to fit it either.
Sera
http://www.motosera.com
jacko
| posted on 9/11/06 at 08:16 PM |
Hi thankyou for the help i got a switch today
Graham
