Kook
| posted on 10/11/06 at 10:30 PM |
Pinto engine loom
This is my First post on here so will say Hello to all and any help will be appreciated.
I am at the stage of wiring the engine up and need a little help.
I read through the posts and see this Diagram but could someone who knows about the Pinto loom to put what each item is as the diagram is a bit
minimal ... I can figure most out but there is a couple of items that am not sure what they are. Cheers Paul
Incase image does not load on the link to pic is http://www.westfield-world.com/Wiring_files/Wiring_frames.html
[Edited on 10/11/06 by Kook]
stevec
| posted on 10/11/06 at 10:56 PM |
Welcome, Which bits are you uncertain about?
Steve.
| posted on 11/11/06 at 12:04 AM |
Which ignition system have you got?
That looks like a generic diagram for points distributor, not necessarily for a Pinto. Not sure what bits of it are
Kook
| posted on 11/11/06 at 12:14 AM |
Cheers that looks bit better yeah its points distributor I am just wanting to start the engine at the min as I am not sure if it a good unit or not
yet as i got a semi complete project.
Thanks for doing diagram Paul
RichardK
| posted on 11/11/06 at 08:17 AM |
The vicky green loom may be of use
LINKY
Rgards
Rich
