nib1980
| posted on 12/11/06 at 05:24 PM |
Sierra stalks mounting and connections
Hi all,
Got the TPS sensor sorted earlier, many thanks.
Got on to the indicators now. Bit of background, I've got a sierra coloumn (I think) it has had the ignition and various brackets removed and
ground smooth. I also have a pair of sierra stalks, that I'm trying to mount. My questions start now....
1) has anyone got anypics of there sierra stalks mounted so I can see how there supposed to be, and what bracketry I need to make up...
2) Also wil I need to use relays and fuses etc to connect them to the main wiring loom, ? I can I connect them directly to the sierra stalks?
Many thanks to all in advance
Paul (Notts)
| posted on 12/11/06 at 06:10 PM |
fix to the two screw holes..
paulf
| posted on 12/11/06 at 06:18 PM |
It sounds as though these may be missing if the column has been cut down to the basic unit.
I would be tempted to use dash mounted switches for the lights and try to find an aftermarket indicator switch that clamps to the column , or else try
to find another column complete with switches. There are 2 types of Sierra switch gear , the old type switches the live circuit and doesnt need relays
or the later type switches the earth circuit amd has to be used with relays.
Paul
nib1980
| posted on 12/11/06 at 06:34 PM |
Hi Paul,
Many thanks. Looking at the picture above the coloumn has been reduced to its basic form, (this is a converted race car. looks like I'm gonna
be making some brakets up to try first then go fo the dash switches.
Is there anyway to tell which switches I have, by part numbers etc?
again many thansk to all
Paul
Paul (Notts)
| posted on 12/11/06 at 07:30 PM |
The switches will have a number and letters stamped on them - cant remember fully but others will help - look for something along the lines of 84GG or
88GG - one type is a switched live and the other is a switched earth so its important!
Paul
