Alfa145
| posted on 13/11/06 at 09:00 PM |
Hazard Switch Wiring Help
I've got the original capri hazard switch but I want to replace it with a new savage switch, but when I come to electrics I'm a bit useless
so looking for some hints and tips on wiring it in.
The original switch has wires:
15
49a
L
R
49
30
What I need to know is which do I map to the new switch which has a wiring diagram like:
  Wiring
Any help welcome
Rob
RazMan
| posted on 14/11/06 at 08:53 AM |
Not sure about the actual switch swap as I kept it simple and used the original hazard switch.
It is worth mentioning that the Savage switch is just two independent changeover switches (top & bottom in your pic) and an led warning light
(centre)
Hope it helps - I am sure someone more knowledgable will be along in a minute
Raz
