numnuts
posted on 15/11/06 at 06:07 PM |
rev counter not working !!
Hi all after some help, i have just fitted webcon gold kit. Engine has fired up straight away but the rev counter is not working . I have removed
another webcon ecu but the digi dash was working fine before . Webcon have supplied a resistor to fit in the tacho feed and 12v live feed , but as
12v feed powers complete digi dash will this work ?? thanks in advance
tks
posted on 15/11/06 at 08:13 PM |
revs
are taken from the coil or mcu wich is basicly an extra coil wich fires together with an other.
you can make up a small electronic board wich count revs.. but its strange that is has left working.
TKs
RazMan
posted on 15/11/06 at 09:58 PM |
Sometimes the output of the ecu isn't compatable with some electronic dashes. My Evodash didn't want to talk to my MBE and I was forced to
use a feed from the coilpack instead.
The resistor you were supplied is probably a way of modifying the square wave output - it usually goes between the 12v signal & earth but
don't quote me on that
[Edited on 15-11-06 by RazMan]
Raz
