Author: Subject: Sierra column wiring diagram
v8kid
posted on 21/11/06 at 08:15 AM Reply With Quote
Anyone got a wiring diagram for the steering column switches on a sierrra ? Thought it would be easy to ring them out but I have to admit failure.
Not a good time to mention I'm an electrical engineer is it?
tks
posted on 21/11/06 at 09:03 AM Reply With Quote
yupsz
or look at my pic archive there is a pic wich says wich pns joins together when doing what!
easy not?
tks
v8kid
posted on 21/11/06 at 09:50 AM Reply With Quote
ok I'll try s-e-a-r-c-h-i-n-g then
posted on 21/11/06 at 10:02 AM Reply With Quote
The Sierra Haynes manual is available online... Worked for me..... Takes a bit of interpreting because its in black and white as mentioned...
Schrodinger
posted on 21/11/06 at 10:44 AM Reply With Quote
There are also quite a few variations of pin combinations
posted on 21/11/06 at 11:10 AM Reply With Quote
There are at least 3 different types of switches and you'll need to know which ones you have before you can wire them up. Early ones used no relays and carried the live but later ones switch the earth of the relays so will not carry heavy current for long without burning out. Somewhere on the switches there is an i.d. like 53g.
Rudy
posted on 5/12/06 at 11:15 AM Reply With Quote
Benb,
may you put a link for the sierra manual on line?
Thankyou
Sorry about my English
