Author: Subject: Help with dash wiring please
mad dad
posted on 1/12/06 at 06:07 PM Reply With Quote
I have the following and would like some help with knowing what the wires go to that are coming out of the plugs if it is possible for someone to answer?????? The first picture is the current dash dials, the second one is the new dash (blackbird i think) and the third is the plugs...hope this is not a stupid question...i have looked at a wiring diagram but am not much further forward!!!! Rescued attachment P1010007.JPG
mad dad
posted on 1/12/06 at 06:09 PM Reply With Quote
mad dad
posted on 1/12/06 at 06:10 PM Reply With Quote
Ian D
posted on 1/12/06 at 09:08 PM Reply With Quote
Assuming its a single layer pcb you can trace some of the PCB rails back to the connector. This will start to eliminate wires. Some of the obvious ones look like warning lamps.
Hope this helps. Alternatively you will need the wiring diagram from the actual vehicle
Ian
mad dad
posted on 1/12/06 at 09:42 PM Reply With Quote
Thanks, as the dials/lights on my dash are all currently working i am wondering if for example i take the wire off the back of my neutral light which wire it needs to be connected to on the plug and likewise for the rev counter, temp gauge etc etc. maybe its not that simple
