Author: Subject: speedo
theconrodkid
posted on 19/12/06 at 04:48 PM Reply With Quote
speedo
got my eye on one of these speedo,s https://www.pmtuning.co.uk/index2.htm (rxin)
it mentions wheel dia from 1-2.5 meters,my wheels are 1.8 meters in dia.
i cant put the sensor on diff pinion as it will be spinning too fast and make speedo read fast,only option i can see is to put sensor on a back wheel/brake drum.
surely this will give a lumpy reading at low speed,any clever ideas on how to do it,where to mount magnet etc?
[Edited on 19/12/06 by theconrodkid]
who cares who wins
pass the pork pies
posted on 19/12/06 at 05:06 PM Reply With Quote
Unless I'm being really stupid why not magnets on the front wheel with the sensor attached to the wing stay bracket?
posted on 19/12/06 at 05:14 PM Reply With Quote
the linky doesn't show the speeod.
and that is bollock, a 2 m diameter wheel? you're looking at dumper trucks, a 6 ft man is 1.85 m tall.
re: following post, putting on front wheel - how do SVA test that? As far as I know, they have 1 roller so unless you have FWD, can't see how you can do it.
posted on 19/12/06 at 05:16 PM Reply With Quote
Do they mean circumference?!?!
2*pi= roughly 6, so a 2M circ wheel is 2 feet diameter...
flange nut
posted on 19/12/06 at 05:17 PM Reply With Quote
The problem with using the front wheels is that at SVA time the tester can't check the speedo accuracy. You have to have documentary proof that it's accurate. If your cars been through the SVA then no problem.
Geoff
theconrodkid
posted on 19/12/06 at 05:23 PM Reply With Quote
sorry thats circumference is 1.8m according to my trusty tape measure and it has to be taken from a driven wheel or it cant be checked
who cares who wins
pass the pork pies
posted on 19/12/06 at 05:27 PM Reply With Quote
I knew that really
I think it is a non starter - it is for mopeds and these have wheels the size of coat buttons; if it were ther other way round, you could get away with 2 magnets and put in 1/2 the circumference measureent.
One possiblility is a PIC to modify the pulses - what is max speedo reading? (it has to show at least what you car is capbable of for SVA)
nd why are you set on this one?
(still not able to see it via the linky)
theconrodkid
posted on 19/12/06 at 05:43 PM Reply With Quote
click on "koso range" and its RX1N,cheap and does all the functions
goes to 223 mph....should be adequate
who cares who wins
pass the pork pies
posted on 19/12/06 at 05:50 PM Reply With Quote
On my first SVA test I presented the car with a bike speedo driven from the front wheel and they said they'd accept it as long as it seemed to be accurate on a drive round the car park..... Probably not what most examiners would do but hey.... Else if you've got IRS, you could mount a sensor onto one of the lower rear wishbone bolts...
theconrodkid
posted on 19/12/06 at 05:58 PM Reply With Quote
ive got a live axle so no chance of that,my first sva tested it at about 4 speeds and i had to twiddle with it to get it right.
could put 2 magnets on and use KPH screen and adjust so that its reads right just says KPH?
who cares who wins
pass the pork pies
paulf
posted on 19/12/06 at 08:20 PM Reply With Quote
Could you fit the sensor through the brake backplate and a magnet on the hub flange somehow? .I considered doing it when i fitted a bike speedo but ended up using the front wheel as i didnt need to worry about the SVA.
Paul.
theconrodkid
posted on 19/12/06 at 08:29 PM Reply With Quote
as the magnet is being fitted to steel/iron,both being magnetic,will the sensor know where the magnet is?
who cares who wins
pass the pork pies
SixedUp
posted on 19/12/06 at 09:29 PM Reply With Quote
Yes.
Richard
posted on 20/12/06 at 09:15 AM Reply With Quote
going back to 1st post; the wheel diameter corresponding to the numbers quoted are 397 - 573 mm.
A 195/50 R15 wheels comes in at 576 so you would be under-reading by 0.5 percent.
So you could just get away with it, fit a lower profile tyre, e.g. 195/45 or smaller tyre.
About the sensor/magnet thing and cast iron(?) drums.
Depends on the sensor type, if it is reed switch then I think it should still work - the cast iron isn't going to "suck" the flux away - the magnet will still should be able to pull the reed switch closed since one end of the magnet is still open to air (you need to put a ferromagentic metal across both pots to "short it out".
theconrodkid
posted on 20/12/06 at 07:11 PM Reply With Quote
ta for the info,ill be on the blower in t morning.
who cares who wins
pass the pork pies
