greggors84
posted on 21/12/06 at 01:48 AM |
Trickle Chargers
Looking to get a trickle charger for the winter as the Indy wont be used for a while especially with my broken leg!
Is there much difference between chargers? Will this £13
one do off ebay. Is there any danger leaving a cheaper one on for long periods?
Chris
The Magnificent 7!
Fatgadget
posted on 21/12/06 at 03:17 AM |
I have opened some of them el cheapo chargers and quite frankly I was appalled by what I saw.
Sorry but I can't really recommend any brand,make
SeaBass
posted on 21/12/06 at 08:05 AM |
Was it like the tardis?? Was there some kind enormous sweatshop inside with children hooked up to the mains transforming and rectifying with their
flesh??
Or do you just mean the components looked cheap and a fire risk?
ned
posted on 21/12/06 at 08:29 AM |
get an optimate, i've taken my battery out of the car and got it plugged in in the kitchen in the warm to the charger which conditions and
checks the level of charge. optimate2 go for about £30-40 iirc on fleabay.
I even went out to the garage on monday and reconnected the battery just to run her up as she's not run for a while..
Ned.
beware, I've got yellow skin
iiyama
posted on 21/12/06 at 08:42 AM |
http://www.barden-uk.com/automotive-chargers.html
used them loads of times. What they dont know about batteries aint worth knowing!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
NigeEss
posted on 21/12/06 at 09:38 AM |
I use an old 400ma 12v mobile phone charger for the bike. Use it once a month
for a week or so, seems to do the trick.
bob
posted on 21/12/06 at 11:12 AM |
Tricle chargers
I bought one of these from machine mart last winter,it worked a treat also sold in argos i believe.
trickle charger link
It also has an led light on the front to show when it is charging,great value
hobbsy
posted on 21/12/06 at 11:14 AM |
I've got a CTEK 3600, expensive but good, see here:
http://www.hamiltonclassic.co.uk/ProductInformation/BatteryCareCTEK.htm
RazMan
posted on 21/12/06 at 11:19 AM |
Second vote for the Optimate - good design & quality kit
Raz
bob
posted on 21/12/06 at 11:29 AM |
optimate
Best price i can see on fleabay
optimate link
posted on 21/12/06 at 12:25 PM |
The optimate is good, I especially like the remote hookup connector- worth making sure that comes in the kit. So much easier than removing the bonnet
after every drive...
The main advantage of the optimate over say the oximiser is the desulfate function on the optimate though I'm not sure how often I'm
actually going to need it.
Although there are cheaper ones out there I'd worry about leaving them continuously switched on and attached to a battery..... Garage full of
petrol, oils, cans of spray paint, GRP, rusted iron fillings and ali filings side by side .....
bob
posted on 21/12/06 at 12:59 PM |
Even though the bonnet comes off after every trip in the car, i have wired in an auxillery power plug on the dash so i can plug the trickle charger in
this way.
Surrey Dave
posted on 21/12/06 at 01:31 PM |
Do you leave that machinemart charger connected for long periods?
bob
posted on 21/12/06 at 03:30 PM |
Dave
I've left it on a timer,it comes on for 6 hrs in the morning and 6 hrs at night.
Although i dont know why i bother as after about 4 hrs its back up to speed,the clarke instruction book says it will cut out at 13.8V or something
like that then come back on at 11. somrthing. I do have a misstrust of clarke products so i thought the timer would be a wise move.
nitram38
posted on 21/12/06 at 08:05 PM |
Don't waste money on expensive chargers! Buy a redtop battery and this will hold a charge for 2 years !
milson
posted on 21/12/06 at 08:24 PM |
i use the optimate no problems leave it plugged in all the time
MikeR
posted on 22/12/06 at 12:24 AM |
Got two from donnington - one for NS Dev and one for me. its spent the last 6 months sat in my kitchen
posted on 22/12/06 at 11:17 AM |
Optimate here
I charge my bike, car and a caravan battery so it can be used on any of them. I have a 12v charger that was £9.99 inc. p&p from ebay but it
doesn't cut out or do a desulphating cycle like the optimate.
scottc
posted on 22/12/06 at 12:05 PM |
What does a desulphating cycle do?
iiyama
posted on 22/12/06 at 12:25 PM |
desulphates!!
Surrey Dave
posted on 22/12/06 at 05:46 PM |
Its all here...........................
http://www.uuhome.de/william.darden/carfaq16.htm
Optimate III seems to only be for bateries upto 28ah , so bikes rather than cars???
[Edited on 22/12/06 by Surrey Dave]
ChrisGamlin
posted on 24/12/06 at 03:14 PM |
Ive used an Oxford "Oximizer" for the last couple of years and cant fault it, does pretty much everything an Optimate does (possibly apart
from desuplhate), comes with a "remote" fly lead and plug so you can mount a plug on the side of the car etc and plug in without bonnet
being open, and costs £25 from M & P
[Edited on 24/12/06 by ChrisGamlin]
