locoboy
posted on 30/12/06 at 01:41 PM |
relay advice
Im missing the Yamaha relay for the headlight cirsuit in my bike loom.
Can you advise which relay on this page will do the job?
VWP relays
Im getting my order together for my wire and terminals etc and need to add a relay to the list.
Locoboy
thunderace
posted on 30/12/06 at 01:43 PM |
contact your local yamaha dealer it wont cost that much.
locoboy
posted on 30/12/06 at 01:51 PM |
I have heard that before!
They wanted £5 + for a Sprocket nut!
besides they wont have one in, i would put my balls on the line in betting they wont.
Locoboy
thunderace
posted on 30/12/06 at 01:56 PM |
try a local bike brakers
bigrich
posted on 30/12/06 at 02:00 PM |
when i did my blade bec i used 2 standard 4 pin relays and holders from my local autoelectric suppliers and rewired both dip and main beam just
remember to get high enough contact rated relays as each circuit will draw around 10 amps
Deckman001
posted on 30/12/06 at 05:24 PM |
T'is best to use a non bike relay for the headlights, as more load is needed than the bike ones can handle, mind you, that was for an R1 install
in an Indy using all the original Ford Sierra stalks as well
Jason
locoboy
posted on 30/12/06 at 10:43 PM |
Anyone got any clues as to which ones i need off the VWP age i linked to at the top?
I spoke to my local Yam dealer and true to form,
Not in stock
£12.50 EACH!
Locoboy
