Author: Subject: i GOT A DONOR ??hahahah
Kamikza
posted on 12/1/07 at 08:48 AM Reply With Quote
THIS I GOT KADETT 1.5TD ISUZU I DOT HIT WHIT A SKODA FELICIJA WHIT 160KM/H
AND I GOT DONOR.ANY BODY GOT AN IDEA IS IT WORTH THE EFORT THE ENGEN IS IN OK AND THE CAR IS WERY AGILE.
WHAT TO BUILD OUT OF IT AND CAN Y BUILD ENYTHING
[Edited on 12/1/07 by Kamikza] Rescued attachment New Image.JPG
dilley
posted on 12/1/07 at 08:57 AM Reply With Quote
macnab
posted on 12/1/07 at 09:32 AM Reply With Quote
If its FWD...
check the gearbox incase it got damaged when the drive shaft was ripped out.
Not an ideal donor, can't you find something a little less smashed??
[Edited on 12/1/07 by macnab]
Kamikza
posted on 12/1/07 at 10:10 AM Reply With Quote
IT IS fr and the gear box is ok the axsel broke in haf living the gear box intact .so what to make
bartonp
posted on 12/1/07 at 10:18 AM Reply With Quote
Sell the parts and buy something more suitable
graememk
posted on 12/1/07 at 10:41 AM Reply With Quote
you could make a camp fire with the bits that will burn then weigh in the rest as scrap metal?
or strip the car ebay the bits from it and put towards something better
[Edited on 12/1/07 by graememk]
macnab
posted on 12/1/07 at 10:43 AM Reply With Quote
Well if you’re serious about using it as a donor. Why not put a post in the mid engine part off the forum and see if anyone can help you make a chassis for it.
That is off course if you are allowed to make you own car where you live. I think I would check local regulations first before starting anything.
macnab
posted on 12/1/07 at 10:55 AM Reply With Quote
Eddie Hitler you and your fires...
iank
posted on 12/1/07 at 11:30 AM Reply With Quote
More suitable in what way, this is the mid engine forum
Kamikza
posted on 12/1/07 at 11:49 AM Reply With Quote
so do you got plans for some thing simple!?
Does not hawe to corner and handle like F1 that is simple hah
Emocional link whit te car he yust kiding i dont hawe money for fuel it is wery expensiv but burning oil is not hahah
Kamikza
posted on 12/1/07 at 03:37 PM Reply With Quote
newer i am a good guy
macnab
posted on 12/1/07 at 06:17 PM Reply With Quote
Sorry about that comment I made Kamikza. It was meant as a joke but really was not at all funny.
Ok, then maybe here is something you and some friends could make. That cars engine and gearbox will go in the back the rest of the bits can come from scrap cars.
Old steel tube could be used and welded up to make the frame just find someone who could bend tube and weld it. This is about as simple as you can make a car and it would be a lot of fun and quite fast.
Although instead you could find the worst VW beetle you can and use that as the donor since none of the rusty metal needs to be used…
[Edited on 12/1/07 by macnab] Rescued attachment rail.jpg
Kamikza
posted on 14/1/07 at 09:39 PM Reply With Quote
no mater i is ok and so baya is the simples as it getstanks for the impot consider us now frends
locost_bryan
posted on 19/1/07 at 03:08 AM Reply With Quote
The original Lotus 7 only had 28hp! - a 1.5 turbodiesel should make more.
You could start with the standard Locost chassis, and convert it to mid-engine by shortening the engine bay, and adding a box frame behind the cockpit to carry the engine and rear suspension.
Pity you lost the driveshaft and strut, or you could have used those at the rear.
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
Kamikza
posted on 22/1/07 at 01:52 AM Reply With Quote
ill buy new ones tanks for the tip !
