locoboy
posted on 15/1/07 at 08:25 PM |
Interpreting wiring diagrams
Im struggling to interpret my R1 wiring diagram.
I have a few questions (yes probably very basic but bear with me!)
1. Why do you have switched earths and switched live feeds?
2. How can i identify a switched earth and a switched live on my diagram?
3. What are the black dots where some wires meet on the wiring diagram below?
4. There are some predominantly black wires with different coloured traces on them on the diagram for example the black wire with yellow at the clutch
switch top left, is this an earth even though its not straight black?
5. The same goes for the red wires, for example red and green from the instruments and red and white from the ignition fuse?
Locoboy
flak monkey
| posted on 15/1/07 at 08:33 PM |
Not sure about the bike colours, but if the earth colour is black then its likely any black with a clourer trace is a switched live.
Basically the difference between a switched live and switched earth depends on where the switch is, if its on the earth side of the bulb say it would
be a switched earth, if its in the live feed it would be a switched live.
The most common switched earth stuff on a car is the brake warning light system of which i have a diagram if you need it.
The black dots on the diagram are where the wires are joined together where they cross/meet.
  r1 wiring diagram
[Edited on 15/1/07 by flak monkey]
Sera
http://www.motosera.com
Deckman001
| posted on 15/1/07 at 09:33 PM |
The Earth lines are the Black lines, the coloured lines are live lines (+) if the powered item has a switched earth, the item will have a permanent
live and will be switched on by giving it an earth via a switch, if the item is switched live, then the earth will be a perm wire, and the live will
be via the switch
any help ??
Jason
Deckman001
| posted on 15/1/07 at 09:37 PM |
If you look at the top part of Flaks picture you can see it says Earth, just to the right of the headlight bulbs, that wire is Black and so should all
the earth cables on the whole loom
Jason
locoboy
| posted on 15/1/07 at 10:15 PM |
What about black with a colour trace?
Locoboy
flak monkey
| posted on 15/1/07 at 10:16 PM |
If the convention is as car looms then black with a coloured trace will be switched earths.
Sera
| posted on 15/1/07 at 10:41 PM |
the black dots are joins. Find all the earth symbols on the diagram and follow wires back. I did this with the zx9 diagrams, after a few attempts it
all made sense.
locoboy
| posted on 16/1/07 at 06:03 PM |
quote: Originally posted by chris mason
are you talking about the little coloured (usually gold/yellow/brownish) bands you get on the solid black wires?
if so ignore them, they are still earth wires.
Chris
Chris,
The wires im talking about are black with a white or yellow or brown line all the way along its length
Locoboy
