MattCraneCustoms
posted on 15/1/07 at 10:02 PM |
Will a Fiat Cinquecento Alternator work on my Zetec?
Hi all,
I've got a Fiat cinqy alternator, and due to the size of it, it would be perfect for the build, anyone know of any problems I'll have
using it? I will need to change the pulley but cant see that as a problem, and fabricating mounts should be easy, but what about rotation? Can anyone
tell me which way the zetec rotates? I havent a clue at the minute.
Matt
Rudy
posted on 15/1/07 at 10:11 PM |
Clockwise
99% of the engine rotate clockwise.
Alternator rotate clockwise too.
Sorry about my English
Rudy
posted on 15/1/07 at 10:19 PM |
If 500 alternator is "trapezoidale" pulley maybe you can not change it to poliv.
If 500 is poliv than there is no problem. If it is 5 poliv instead of 6 (as in zetec) it is no problem, you will use a 5 poliv belt.
I used standard mondeo alternator.
posted on 16/1/07 at 11:10 AM |
that may be a problem; the hole in the pulley should be same as that of the spindle, a smaller hole can be enlarged. (old lucas havre smaller spindle
than newer ones).
Also the pulley need to run in the same plane, you should be ableto correct that wit your mounts.
Also alt/crank pulleys should have diameters 1:2 (i.,e. alt runs at twice engine speed). If you have too small alt pulley and run at high rpm, it
ain't gonna be happy.
If you need a simple v-belt pulley, I may have details of a man who can make one out of ali for about £ 30.
Aslo direciton - if you have a wide belt (serpentine arrangmement) then you need to be sure the alternator turns in same direction as engine (I
can't see why ot won't work in the oppostie drirection but better to go with knowns).
tks
posted on 16/1/07 at 12:20 PM |
it will work
only the cooling fan is the problem..
sow you need to turn in the direction..
Tks
