Author: Subject: Where can I get these battery connections?
speed8
posted on 28/1/07 at 04:29 PM Reply With Quote
I could do with getting them tomorrow so I can crack on with a few things.
One is a right angle connection off a bike battery and the other uses an 8mm bolt to hold it in place on the starter relay.
battery1
battery1
battery2
battery2
RazMan
posted on 28/1/07 at 04:45 PM Reply With Quote
Premier Wiring does a range of battery terminal connectors.
Raz
stevebubs
posted on 28/1/07 at 08:04 PM Reply With Quote
autosparks are worth a shot....
bigrich
posted on 28/1/07 at 10:58 PM Reply With Quote
just carefully unpick the ones you have Andy. I did this with no probs on my last build
speed8
posted on 29/1/07 at 09:56 AM Reply With Quote
I like it... lo-cost and simple. Wasn't sure if I would destroy them in the process.
RazMan
posted on 29/1/07 at 10:15 AM Reply With Quote
Might be a good idea to solder the used ones back on though - they might not grip reliably when second hand
Raz
posted on 29/1/07 at 10:55 AM Reply With Quote
tha't worth a go; maybe using a small drill to drill out the wire first, then pull out the remaing strands; then a screwriver to prise the tabs open?
