Author: Subject: Weber alpha ECU to Megasquirt/spark????
se7ensport
posted on 31/1/07 at 10:12 AM Reply With Quote
I need to replace my Weber Alpha ECU with Megaspark or magasquirt (or another ECU if easy enough to map on own laptop).
I've got a few questions:
Can I use MSquirt with carbs to start with and then easily switch to injection at a later date, or should I just use megaspark?
I already have EDIS (I think that’s the right initials for the coil) and engine sensors fitted i.e. engine temp, air temp, TPS, crank sensor, can these be calibrated to be used with MS as my wiring loom is a very neat install and it would be a lot easier to swap the ECU's over (okay different connectors but easy enough)??
If I buy a prebuilt MS system and download an existing map for a similar spec engine is it just a case of connect sensors, calibrate them if necessary and away I go?
Alex
goeslike
posted on 31/1/07 at 05:27 PM Reply With Quote
Have you had trouble with alpha - is megasquirt better? Why change?
se7ensport
posted on 31/1/07 at 08:00 PM Reply With Quote
As I've gone for bike carbs I can't get anyone to tune it, weber only give their software to approved dealers and they won't touch bike carbs! as the engine is currently standard it works really well, however, as i'm looking to either tune the engine or swap to another engine I need a flexible ECU that I can initially set up.
For a standard engine the alpha is the best from the box as they are mapped for specific engines.
