se7ensport
posted on 2/2/07 at 09:19 PM |
Sharing ECU maps
Now this may not appeal to the ones who race, but many of us have very similar engine specs and the ability to download maps for similar spec engines
would save a lot of time, does an existing list already exist? if not is there interest in setting one up??
Even if people are using different ECU's the reference points will still be very close.
Alex
givemethebighammer
posted on 2/2/07 at 10:08 PM |
I'm always interested in how other people have set their cars up and I am more than willing to share my ECU maps / carb settings etc. Just a
case of how it could be done.
TangoMan
posted on 2/2/07 at 11:28 PM |
I would happily share the MJ maps I have for a Pinto and will share those I create for the Zetec/MS once it is up and running.
A good idea as I see lots of posts on forums requesting maps for various installs.
Summer's here!!!!
RazMan
posted on 2/2/07 at 11:48 PM |
Anybody is welcome to share my maps, although I didn't realise that you could use the files on different ECUs.
Raz
graememk
posted on 3/2/07 at 12:01 AM |
welcome to mine
anyone else running a nissan 1.8 turbo ? if there is can i have your map as my car runs like i own a shares in esso
Schrodinger
posted on 3/2/07 at 08:59 AM |
I have a map for a 1.8 Zetec with TBs 2.0l cams and an Emerald ecu if its any use.
zzr1100rick2
posted on 3/2/07 at 10:14 AM |
i will share mine msns 2.0 zetec std inlet when i get it running to a sva standard
Danozeman
posted on 3/2/07 at 10:22 AM |
Ill share mine for my zetec and bike carbs when i get it right. Also any more i have!!
Mines being a right PITA at the min. cant get it right.
Dan
se7ensport
posted on 3/2/07 at 12:36 PM |
My understanding is that you can share the data between different ECU's as long as you can maually input the data, i.e. it doesn't matter
on the make of ECU as its all about X revs = Y advance etc.... after all they are just reference points, a bit like a look up table in Excel
An area on the site where we can each save maps would be ideal, anyone got a suggestion of the exact how? is there an easy way to output maps into
excel???
martyn_16v
posted on 3/2/07 at 03:54 PM |
Excel
To some extent yes, but i'd imagine it'll turn out to be nowhere near as simple as that. For example advance figures in the table could be
an actual advance, or an value added to the base advance set by the dizzy position or elsewhere in the software. Fuelling will be even more variable,
you can use injector pulsewidths, VE, a variant of it such as MS's VE*AFR, or even something totally arbitrary (i.e. just a number) that the ecu
uses to work out pulsewidths with later. Translating these from one ecu/format to another isn't going to be trivial in some cases
