wacomuk
posted on 6/2/07 at 07:03 PM |
Advantages of a straight cut box ??
What are the advantages of a straight cut box over a semi helical box ?
faster gear change?
handle more power?
http://www.insightbookingsolutions.co.uk
DIY Si
posted on 6/2/07 at 07:05 PM |
Handles more power. Faster changes may happen too, but if so it's due to uprated synchro bits rather than the straight cut gears. A dog box will
give a faster change though, but that's normally a whole new level of expensive!
Oh, they also sound brilliant!
[Edited on 6/2/07 by DIY Si]
Sun Tzu, The Art of War
kikiturbo
posted on 6/2/07 at 07:09 PM |
straight cut box has less frictional losses... and, you have no axial thrust when using straight cut gears... also, as far as I am aware, straight cut
gears are a bit stronger..
now, shifting is a matter of using synchro mesh or dog angagement with no synchro rigns... but that has nothing to do with helical or non helical
gears, you can have a non synchro box with helical gears...
straight cut boxes have some free movement between gears and are much more noisy...
nasty-bob
posted on 6/2/07 at 07:15 PM |
I've always found this one a bit strange because as I understand it, helical gears are inherintly stronger as the load is spread over 2 teeth as
opposed to one with straight cut.
Straight cut gears don't however produce the axial load that helicals do so maybe thats why they are seen as more robust.
Also, I would imagine replacement straight cut gears are made from better materials than the standard mass produced helical ones.
DIY Si
posted on 6/2/07 at 07:18 PM |
It is normally spread over 2 or more teeth, but only part of them so the difference in contact area is minimal. The teeth on straight cut gears tend
to be thicker and made of better materials, so are stronger. Ie 1 big tooth is better than 2 halves of weaker ones.
jack trolley
posted on 6/2/07 at 07:28 PM |
They sound bloody awful - an incessant whine
John Bonnett
posted on 6/2/07 at 07:33 PM |
I agree, they do sound awful. I am running a Trannex straight cut box and on the road it's a real pain but it does handle the power and on the
circuit a bit of a whine is no problem.
posted on 6/2/07 at 07:40 PM |
Real reason is down to manufacturing it is much easier to cut straight cut gears.
greggors84
posted on 6/2/07 at 10:04 PM |
I agree with Calvin! They sound delightful!
Chris
The Magnificent 7!
greggors84
posted on 6/2/07 at 10:05 PM |
So racing cars use straight cut gears because they are easier to manufacture?
Chris
The Magnificent 7!
givemethebighammer
posted on 6/2/07 at 11:09 PM |
Thirded, I love the sound of my TranX box (the ratios are great too)
nick baker
posted on 12/2/07 at 11:18 AM |
I agree too.. As an ex mini-nut ..(well, scamps really) there's nothing like the whine of as traigh cut box and the wail of a stressed A-serised
engine to make me smile...
The tooling and Methods of manufacturing gears either helical or straight are usually very similar. The only difference is that the helical gears need
to be rotated while being cut.
The main reason Helicals are used in production machinery is the reduced back-lash and and constant mesh of the teeth, hence reduced noise.
The teeth slide against each other in more places with a helical cut: this reduces the efficiency of the power-transfer.
As has been pointed out before, Axial thrust is a big issue with helical cuts leading to the use of large thrust bearings.
Straight-cuts transfer power with more efficiency, and at the "cost" of higher noise.
Personally I'd pay more for the privaledge of a straight-cut 'box. That noise is the best soundtrack to drive with....
posted on 13/2/07 at 07:42 AM |
It was the only option in the old days because companies like Hewland and Jack Knight started out as garden shed operations, and the Machine tool
needed for hobbing a straight cut gear is much simpler ad cheaper. Also back in the early days of Formula Ford the cost of gear sets was very
important.
