markal
| posted on 6/2/07 at 07:35 PM |
How do you start a car?
How do i wire an engine up on a test stand, it has plugs, points and condenser, no fancy computers, just the old fashioned stuff, i want to make sure
the engine is fine before i install it, regards Alan
John Bonnett
| posted on 6/2/07 at 07:42 PM |
Hi Alan, not too much of a problem. I suggest you wire through an ignition switch which has a position for start and this is where the cable to the
starter solenoid goes. There is a position for your feed, the battery and one for ignition. this would include coil, distributor fuel pump etc. if I
haven't forgotten anything, hopefully that's all you need to do.
John
Rossy
| posted on 6/2/07 at 07:49 PM |
It sould be simple
However...you need the starter motor and flywheel on the engine so depends as some fix to the gearbox..
Starter should have the following...
Perminant Earth and Live and a push on release off live...i.e. a button so when you bush it it terns the engine over and when you let go it stops..
Coil should be already earthed (via the starter being bolted to the engine) it then needs a live feed this is the equiv of ignition on..so when this
is removed the engine dies.
I'd say this is the most important and personaly would use another push switch and have someone else hold it in why the engine is started..for
safety reasons.
That way if there is any problem what so ever the engine will be cut once that button is releast!
How are you going to mount the engine for example...if its on a make shift jig and it vibrates off you dont want an engine jumping around your garge
floor!!!
Hope that helps and good luck...
Oh and if it gets too much simply buy one already done..prefferably MINE!!
Its up for sale in the for sale section!!
PLug plug plug.....
[Edited on 6/2/07 by Rossy]
<---- For Sale :~( See for sale Section)
He who walks in front of my Locost 7 will get tyred. He who walk behind me will get exhausted. He who drive it like hell will get there very
quickly!
(Love Open Countryside, Overtaking Slower Traffic)
907
| posted on 6/2/07 at 09:41 PM |
It seems like years ago when I fired mine up for the first time. What am I saying, it was.
No fancy switches in this neck of the woods. A few bits of wire and crossed fingers.
A wire from battery though coil to dizzy, fixed to battery with a crocodile clip. (disconnect to stop engine)
The heavy starter wire was in, as was the earth, so just a wire from starter solenoid which could be touched on the battery to fire the motor.
The alternator was wired to the battery as I believe if an alternator is run without being connected it may blow the diodes in it.
You'll notice the G clamped piece of metal with the expansion tank taped to it and the Fuel tank above that.
Fuel on. (remove clothes peg from fuel pipe)
Ignition. (crocodile clip on)
Contact. (touch wire on battery, wire sparks & burns finger. Drop wire and suck finger)
Contact again. (holding wire further up)
Music to my ears.
What a day that was.
Paul G
| posted on 6/2/07 at 10:12 PM |
If you are going to start it on a test stand make sure it's well tied down just in case and as Paul has said a few pieces of wire with crocodile
clips would get it running.
markal
| posted on 7/2/07 at 03:41 PM |
Have a look at my test stand? in my photo archive, it aint comming out of there, regards Alan
macnab
| posted on 8/2/07 at 10:11 AM |
I have run my vw flat fours with them just sitting on the ground on a piece of carpet. To be honest not a lot happens, just starts runs and thats it,
no hopping about or anything. No need for a test stand at all.
| posted on 8/2/07 at 05:43 PM |
A flat four is somewhat more stable sitting on the ground than an inline 4, which quite often won't even balance on their sumps by themselves!
