Author: Subject: rear light mounts..interested?
SteveO
posted on 7/7/03 at 02:49 PM Reply With Quote
Hi all,
This is just to find out how many of my fellow locosters will be interested in rear round high mounted light holders similar to below pic.
DaveFJ
posted on 7/7/03 at 03:19 PM Reply With Quote
Dunno about that but would be interested in more pictures/details of the car in the picture.......
jonti
posted on 7/7/03 at 03:57 PM Reply With Quote
I know my old eyes aren't wot they were but I cant see a picture.
Is it a very small one then ?
Shall I get me milk bottle ?
OFROK
posted on 7/7/03 at 04:08 PM Reply With Quote
It's got no rear reflectors, is it on the road?.
SteveO
posted on 7/7/03 at 04:18 PM Reply With Quote
i'm trying to get hold of just the rear light holders thats why the pic is on here folks.
Just sampling if the look will go down well with locosters. It does take a lilltle while to appear, depending on speed of your pc link.
Northy
posted on 7/7/03 at 05:46 PM Reply With Quote
I'd like some
Graham
posted on 7/7/03 at 07:27 PM Reply With Quote
It's a piece of downpipe with a set of landrover lights glued into it isn't it.. The custom crew used to do it the other way round sinking the light into the panel, called it frenching for some reason.
yours, Pete.
stephen_gusterson
posted on 7/7/03 at 08:25 PM Reply With Quote
i have made 'light holders' like that just recently for the back end of my car - morgans have that look.
wasnt that hard. formed the shape from card, then cut out some scrap 1mm steel, using card as template, formed it into a tube around a similar dia object, then welded it and buffed the welds flat using a flap wheel in a drill stuck in a vice.
used cheop lights that look quire good, having the rubber recesssed into the holder.
if interested, I can post pikkies.
atb
steve
[Edited on 7/7/03 by stephen_gusterson]
SteveO
posted on 8/7/03 at 09:38 AM Reply With Quote
I tried making some, but didn't look great.
These ones are made from light weight plastic- cheaper; or may get them in rolled ali'
stephen_gusterson
posted on 8/7/03 at 10:06 AM Reply With Quote
mine look ok.
the trick is the following.
1. allow a bit extra at the lamp end to cut away to allow a better edge to the welded seam.
2. dvelop the shape from card - its actually a kinda sine shape - not as linear as you might expect.
3. Use edge strip as it meets the body.
atb
steve
jonti
posted on 9/7/03 at 12:37 PM Reply With Quote
[It does take a lilltle while to appear, depending on speed of your pc link.
Halleluiah I see de light !! (patience never was my strong suite) It's me steam driven PC y' see. I like em though.....how much athy ?
OFROK
SteveO
posted on 10/7/03 at 09:45 AM Reply With Quote
will get back with cost soon folks.
