Author: Subject: digi dash oil sensor
dilley
posted on 26/2/07 at 08:06 PM Reply With Quote
I noticed a small oil leak from the flexi pipe that mounts the oil/low oil pressure switch, It worked its way loose at the engine endmust have had a slight twist in the flexi when I routed it to mount the switch, Just thought id post incase anyone wants to check thiers.could have been really,really bad
tks
posted on 27/2/07 at 06:28 AM Reply With Quote
if you use a copper washer and applied its torque i cant see wy it would come loose??
Tks
