Author: Subject: Old Skool Dash
caber
posted on 10/3/07 at 07:26 PM Reply With Quote
Old Skool Dash
What do you think folks?
Caber
[Edited on 3/10/2007 by caber] Rescued attachment Photo_031007_003.jpg
blakep82
posted on 10/3/07 at 07:29 PM Reply With Quote
oooh, i like
nice one!
________________________
jos
posted on 10/3/07 at 08:17 PM Reply With Quote
old skool rules
if it was mine i'd cover it but its not so up to you
goodall
posted on 10/3/07 at 08:41 PM Reply With Quote
oh its not wood
hows it old school?
im not being veracious, i am confused
[Edited on 10/3/07 by goodall]
ecosse
posted on 10/3/07 at 08:46 PM Reply With Quote
Nice 1 caber...who needs a digidash
Alex
cossiebri
posted on 10/3/07 at 09:24 PM Reply With Quote
Originally posted by robocog
Nice :-)
You going to cover it?
Mine is polished ally and its a bit blinding when the sun is low - but at least the missus doesn't keep turning the rear view mirror to check shes still there - or whatever it is they like to check on
I'm thinking of covering mine with viynl or something just to cut down the glare.
How about vaseline or grease?
If it doesn't fit MODIFY it!!
Cheers BriF
dl_peabody
posted on 10/3/07 at 09:55 PM Reply With Quote
I LOVE IT!!!!
How did you fit the dash? Bonded it? Welded it? Looks like you built the skuttle frame (Double Hops) and built your dash into it...Very clean and neat.
Only sad part is seeing the open tube end in the skuttle frame.
I see the bolt holes now...Nice....
[Edited on 10/3/07 by dl_peabody]
jlparsons
posted on 10/3/07 at 10:20 PM Reply With Quote
Nice mate! Looks good enough to shoot down meschersmits.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
paulf
posted on 10/3/07 at 10:50 PM Reply With Quote
Looks similiar to mine, I made my dash when the large SVA steering wheel was fitted and now find that the smaller wheel obscures the instruments a bit. I was planning on making another with them situated in the centre rather than behind the wheel but havent got around to it yet.
caber
posted on 10/3/07 at 11:18 PM Reply With Quote
Scuttle is ally wrapped over steel, the dash is "brushed" with course scotchbrite though it may get a viny covering depending if I have enough material left after the seats. Old Skool as it is same layout as early Cateringvan
I am mgoing to make some triangle fillets as per Lotus 7 and cateringvan to hide the tube ends and, if I can find them ( the lockup is a bit of a mess ATM!) I have stainless countersunk screws and cups to hold it in. I am not sure if I will have to pat the scuttle edge for SVA the rules are not very clear apart from the 19mm radius on the BOTTOM of the dash panel.
I am still working on the handbrake, you can see the genuine Lotus umbrella handle below and right of the steering wheel, then its wiring time
Caber
DavidM
posted on 10/3/07 at 11:26 PM Reply With Quote
Nice job!
When are you expecting to be on the road?
caber
posted on 11/3/07 at 07:44 AM Reply With Quote
Hoping to be on the road this summer. I have got to fit the engine and see if it can be made to work I have 2 so I am hoping I can get enough working bits to make a decent runner!
Caber
907
posted on 11/3/07 at 08:51 AM Reply With Quote
Love it
Paul G
