Moorron
posted on 12/3/07 at 10:23 PM |
neutral wire confusion (bec)
just as a tempory measuere while i design my new dash i need to fit an led to show im in neutral, bored of stalling it on junstions. But i was sure
that all bike engines neutral wire just switch to earth when in neutral? however i connected an 12 volt led up and its resonably bright (10 volts) in
any gear and normal brightness (12 volts) in neutral.
whats going on?
cbr1000f
Sorry about my spelling, im an engineer and only work in numbers.
posted on 12/3/07 at 11:06 PM |
Sounds strange! AFAIR all are a switch to earth.... You shouldn't get anything in any gear other than neutral... I'd agree- check the
engine earthing ? floating earth relative to the engine or something wierd like that...
posted on 13/3/07 at 12:28 AM |
The neutral wire on some bikes also is used for the sidestand etc as this is part of the safety start procedure. Neutral, side-stand up and clutch
lever pressed.
If yours is this type sounds like you are getting a rogue feed from somewhere else.
