Author: Subject: O/T flasher relay
posted on 13/3/07 at 08:22 PM Reply With Quote
O/T flasher relay
the flasher relay in the tintop has started misbehaving, banging on and off repeatedly. Trouble is someone has modified it in the past. Its meant to be a 3 pin one, but currently has a 4 pin one with a wire soldered onto the spare leg. Wire seems to go to a small bulb, which flashes once when you indicate but doesnt go with the flashers.
Any ideas whats going on here?
tks
posted on 13/3/07 at 08:42 PM Reply With Quote
mhhh
i guess that small bulp is blown..
or has a bad connecion??
else the hole unit needs replacement
Tks
bigrich
posted on 13/3/07 at 10:30 PM Reply With Quote
extra pin is for tow bar the lamp will flash when trailer is connected
locoboy
posted on 14/3/07 at 08:03 AM Reply With Quote
my 406 has a random green light down by the little pocket to the lower right of the steering wheel which flashes with hazards but not with the indicators, i figured its for indicating your trailer lights are working too.
Locoboy
posted on 14/3/07 at 08:23 PM Reply With Quote
this is a citroen ax with no towbar. Im sure someone has fitted the light so they can use a 4 pin relay for some reason. Might just try a 3 pin one anyway.
