bob
posted on 16/3/07 at 07:53 PM |
loom protection fuse
Probably should have put one in 1st time round, i'm nearly finished the re wire front end i thought i would this time.
Question is what rating ?
I've got one of those strip fuse links for the job and it has a 30 amp strip in it,would this be ok.
grahamgg
posted on 16/3/07 at 08:03 PM |
I once had a renualt 25,and the main fuse went,we could not find it anywhere,until it started to get dark and i flicked the ignition,we saw a small
spark coming from the front engine bay by the headlights,,anyhow it was rated at 30amps..
bob
posted on 16/3/07 at 08:06 PM |
Thanks graham, i bought the fuse some years back and thought it was good enough.
omega 24 v6
posted on 16/3/07 at 09:00 PM |
I'm going to use a 70 amp main fuse for the whole system (excluding starter/alternator.
RazMan
posted on 16/3/07 at 11:01 PM |
30A is a little small for a main fuse IMO. I would use a 50A
Raz
dave r
posted on 17/3/07 at 07:35 AM |
rover metro and 200 series are a good source for a small mega fuse block
think it holds up to 4 big blade fuse's
and is quite neat, and the mounting clip is easily attached to the battery clamp bar
allows you carry a spare or too as well
turbodisplay
posted on 17/3/07 at 08:22 AM |
Fuses
Vauxhall vectra mk1 is my source of loom fuse,
box by battery containing 5 x 60A maxi fuses, 1 20A fuse.
For your first try of the loom use a battery charger as these are limited to 8A max.
Almost finished my loom, has anyone used the modular rockers on their car - are they sva compliant?
Darren
