dilley
posted on 21/3/07 at 11:15 AM |
fan cable tie thingys
I need some of the cable tie clip things that go through the rad to hold the fan on, any ides? if I know there correct name it would help!!
graememk
posted on 21/3/07 at 11:17 AM |
i used normal cable ties with a modification, then i pu'd the fan in place to cut down on vibration
Macbeast
posted on 21/3/07 at 11:24 AM |
Maplins will have cable ties
posted on 21/3/07 at 11:47 AM |
Car builder solutions do the mounting kit but yes- you can probably DIY something and save some cash in line with the Locost mentality!!
dilley
posted on 21/3/07 at 12:07 PM |
locost option went out the winow ahen I phoned holeshot a year ago
RazMan
posted on 21/3/07 at 12:19 PM |
Don't use them! They will eventually wear through your radiator core and leave you stranded on a wet, cold winters night. (guess how I know
Do it properly and make a bracket - that's a permanent solution.
Raz
ned
posted on 21/3/07 at 12:31 PM |
quote: Originally posted by CaLviNx
i nearly hit the floor when he asked for near on a tenner for a mounting kit...... you can guess what i said to that idea.
"Good day" ?
beware, I've got yellow skin
dilley
posted on 21/3/07 at 12:52 PM |
te problem with a bracket is that I cant get the fan tight to the rad.
robinj66
posted on 21/3/07 at 01:40 PM |
Someone on the Cobra site managed to get small tubes soldered (?) through his matrix to allow the cable ties to pass through to avoid the cable ties
sawing through the rad.
tks
posted on 21/3/07 at 01:45 PM |
if there is place for a Tie wrap you can also penetrat some M5 volts just use a old drill and a hammer it gives way
(slowly offcourse) and pick a good place
get big washers (penny) and you should be done with 2 bolts in diagonal.. put the nuts (nylocs) on the front to cool the nyloc down or else put 2
normal nuts on (better)
Tks
p.s.
saying that i have quet some room between the 2 saying that 2 witht he nosecone on i don't think its much differece and when i trew something
before the rad it would just stick to it
James
posted on 21/3/07 at 05:00 PM |
I'm pretty sure it was the article in PPC that suggested it was best to leave a gap between rad and fan anyway.
James
- Muhammad Ali
posted on 21/3/07 at 06:55 PM |
dilley, I think I have some in the garage but doubt if I will be able to look until saturday . If thats any good you can have them .
dilley
posted on 21/3/07 at 09:47 PM |
cheers rusty
