Author: Subject: Sierra Estate
saigonij
posted on 26/3/07 at 02:46 PM Reply With Quote
Sierra Estate
All,
Is the rear end of a sierra estate the same as a normal Sierra?
Im trying to find a donor car and a sierra estate has come up.
Ian
mookaloid
posted on 26/3/07 at 03:02 PM Reply With Quote
Estate should be no problem - I used one in my Indy without issues.
Kev99
posted on 26/3/07 at 03:05 PM Reply With Quote
Thats what I used no problems
chrisg
posted on 26/3/07 at 03:09 PM Reply With Quote
That's correct - the differences are in the bits you throw away, the trailing arms shocks and spring locations.
Chris
saigonij
posted on 26/3/07 at 03:48 PM Reply With Quote
brill.
thanks guys.
TGR-ECOSSE
posted on 26/3/07 at 05:35 PM Reply With Quote
I used a 4x4 sierra estate. LSD rear end
[Edited on 26/3/07 by TGR-ECOSSE]
mark_mcd
posted on 26/3/07 at 09:22 PM Reply With Quote
ok i'm really confused now! i thought you couldn't use an estate as a donor as some parts are different from the hatch that you need? can someone put me right here?
[Edited on 26/3/2007 by mark_mcd]
posted on 26/3/07 at 09:33 PM Reply With Quote
its exactly as chris says, the bits that are different are the ones you dont need.
