posted on 30/3/07 at 10:53 AM |
Indicator Position.
Sorry, I've asked this before but I'm more confused now.
I would like to mount my indicators AKA caterham style, under the headlights on the same bracket.
My MNR has a slightly longer nose cone than the Caterham and I was wondering if this causes a problem with the field of view.
Also any advantage of nice big indictaors on the front of the nose cone when it comes to SVA and external protrusions on the front suspension.
Any expert advise would be much appreciated.
[Edited on 30/3/07 by coozer]
Guinness
posted on 30/3/07 at 11:00 AM |
I think these are the current images from the SVA manual.
As long as you can see the lamps from within those angles you should be OK?
Light Angles Side
Light Angles
I guess the only way to tell is to temporary fix the lights with cable ties / tape and then have a wander round the car with a protractor!
Hope that helps.
Mike
russbost
posted on 30/3/07 at 11:03 AM |
If the nose blocks field of view then mount them higher for SVA & move them afterwards - bear in mind tho' that it's rather a good
idea for people to be able to see them.
smart51
posted on 30/3/07 at 11:13 AM |
The headlights only just meet the visibility angles viewed from the side at 45° because the nose cone blocks almost half of the lamp's lense.
Mounting the indicators below this will almost certainly fall foul of SVA rules.
Caterham get away with this by mounting the headlights really high up.
posted on 30/3/07 at 11:31 AM |
To get round this I made up some indicator spacers (now removed!!)- see
They're basically a length of black 40mm drain pipe with some MDF end pieces at either end (OD same as the indicator light) ID same as drain
pipe....
Glue them in, spray them black jobs a good'un....
Worked for me @ SVA...
miegru
posted on 30/3/07 at 12:33 PM |
Hi BenB,
Hats off to your solution. Clever, simple, cheap and simple to remove. That's what I like about this forum. Loads of creativity!
Rgrds,
Mies.
posted on 30/3/07 at 12:38 PM |
Great idea, loverly jubbly ben, that looks the dogs bo$$ocks. Saves drilling holes in the nose cone.
speedyxjs
posted on 30/3/07 at 01:07 PM |
Is it SVA safe to mount the indicators inside the nosecone so long as it can be seen from those angles? I was going to use the sidelights/indicators
from my donor car but this thread has got me wondering whether the might be too close together.
miegru
posted on 30/3/07 at 01:19 PM |
Inside the nosecone is not possible. The indicators have a maximum distance from the sides of the car. I almost failed on that; only 1mm to spare...
posted on 30/3/07 at 01:55 PM |
Cheers peeps. Worked for me! Even attached the temporary spacer in place using the same layout holes as the indicator so it only took 5 minutes to
unscrew it all and remove the stalk post SVA
Macbeast
posted on 30/3/07 at 02:22 PM |
Front indicators maximum of 400mm from edge of widest part of the car. (Widest could be outside of your rear wheels)
Minimum separation between left and right indicators is 500 mm.
hope this helps
posted on 30/3/07 at 06:43 PM |
You could always mount them on top of your front arches (ala original VW Beetle) - to be different.
