bikkel
posted on 10/4/07 at 06:45 PM |
powercommander question
Hi all,
just tested my car again
i'm not sure about the powercommander on my zx12 (wired by the previous owner)
is there a good manual for operating this PCIII?!
is it correct that only the bottom led burns in normal use?
as indicated by the arrow below...?
![](/galpreviews/pc.jpg) ![Description](/gallery/pc.jpg) Description
koen
www.zx12r-indy.tk
imp paul
posted on 10/4/07 at 07:27 PM |
here you go
i hope this helps you sort things good luck paul http://66.132.187.150/powercommander_iii_usb/powercommander_general_downloads.aspx
[Edited on 10/4/07 by imp paul]
posted on 10/4/07 at 08:29 PM |
I believe in normal use this is the position of the throttle position. At its lowest position it's idling.
When tuning its function changes... of course I'm only familiar with ours which is slightly different!
G.Man
posted on 11/4/07 at 03:51 AM |
Hellfire is correct default display is throttle position
Opinions are like backsides..
bikkel
posted on 11/4/07 at 03:59 PM |
thx
koen
www.zx12r-indy.tk
bikkel
posted on 29/4/07 at 06:11 PM |
today I calibrated the throttleposition sensor to the PCIII using the serial cable&software.
now the leds are OK ( moving along similar to the throttle pedal)
koen
www.zx12r-indy.tk
the moa 2
posted on 29/4/07 at 06:29 PM |
IMP PAUL Love your imp looks great been looking through your archive and just curious we you fitted the sierra diff when you could have went for a
chain and sprocket set up.
