Guinness
posted on 9/5/07 at 09:35 AM |
Can Thermostatic Switches Fail?
My fan has stopped coming on automatically. I have an overide switch wired in so it's not a problem at the moment, but can thermostatic
switches fail?
And why? What is there to go wrong inside the block of brass?
I have a Ford switch in my rad that controls the fan (no relay).
Mike
Mark Allanson
posted on 9/5/07 at 09:38 AM |
They are always going wrong, usually when you disturb them (I work in a bodyshop - always changing rads). We change VAG ones as a matter of course on
any car over 5 years.
gingerprince
posted on 9/5/07 at 09:42 AM |
are your water levels okay? if you're running low on water you may get no flow past the stat, therefore no temperature for it to switch.
Dave J
posted on 9/5/07 at 09:48 AM |
I had one fail, fitted new one and put in a failsafe switch on dash.
cheers
Dave
posted on 9/5/07 at 09:55 AM |
fit a relay --- fans take a lot of amps
Danozeman
posted on 9/5/07 at 03:10 PM |
Fan switches go all the time. Fit a new one and wire a relay in so theres less load on the switch..
Dan
