Author: Subject: FIA Battery CutOff Wiring
greggors84
posted on 16/5/07 at 09:32 PM Reply With Quote
Got a FIA Battery cut off switch off the T-Car team at work.
At the moment I have a standard cut off switch, how do I need to wire up the alternator so it wont blow when I cut the switch with the engine running.
The new switch I have has a small block on the bottom with 4 spade connectors on it. The electrics guy at work said I will need a ballast resistor (which I can get off him). Does anyone have a wiring diagram for the switch and resistor?
Chris
The Magnificent 7!
worX
posted on 16/5/07 at 09:45 PM Reply With Quote
just searched google and came up with this as the top entry...
http://www.dazecoop.co.uk/15-06-2006/wiring-battery-cut-off-switch
hth
viatron
posted on 17/5/07 at 10:10 AM Reply With Quote
I think this has the answer
http://www.websitetoolbox.com/tool/post/viatron/vpost?id=1896001
ChrisGamlin
posted on 17/5/07 at 11:56 AM Reply With Quote
hth
LOL, the second diagram in that link is one I drew up when I wired mine in, but it may be different as this was for a BEC
[img][/img]
greggors84
posted on 26/5/07 at 10:12 AM Reply With Quote
Thanks for the links. Still a bit confused though. At the moment the alternator has the main output going to the starter which is then connected to the battery. It has the 12v 'exciter' feed coming from a switched live via a warning lamp.
Do I need to wire the exciter feed across the N/O terminals on the cut off switch so that when I turn the switch off the feed is killed to the alternator?
Where does the ballast resistor come into it? I can see the resistor in your diagram Chris, but it doesnt mention the alternator.
Sorry if its stupidly obvious!
Chris
The Magnificent 7!
greggors84
posted on 26/5/07 at 10:20 AM Reply With Quote
Just went back and re-read the piston heads topic. Think I have my head around it now! I can also see why the alternator wasnt mentioned.
Maybe I should search google more before asking!
Chris
The Magnificent 7!
Bob C
posted on 26/5/07 at 04:59 PM Reply With Quote
Just disconnecting the battery won't stop the engine as the alternator will supply the juice. Because the alternator can supply over 50amps you don't just put the alternator output through one of the smaller switches, it's normal to put something like the ignition coil 12V feed through so the engine will stop but there's not so many amps it will tater the switch. Now when you hit the big red switch there's no drive or load on the 12V so it 'could' float around for a while causing general embarrassment - so the 'ballast resistor' circuit is there to pull it down to deck.
Bob
thomas4age
posted on 29/5/07 at 01:34 PM Reply With Quote
in other words, if you don't use the pull down resistor some alternators will then put up to 80volt's on the system because it can't see the battery anymore and thinks the Battery is flat, thus going into rappid charge, with no load, hence voltage goes up.
prepare to replace everything that's turned on at that exact moment.
grtz Thomas
learned the hard way once! had 81volts on the laptop multimeter interface.
If Lucas made guns, Wars wouldn't start either.
