mattandmike
| posted on 17/5/07 at 08:00 PM |
Brake test light.
We are using a Sierra master cylinder, & I need to wire up the test light. There are 3 spade connectors on the master cylinder cap. Can anyone
tell me how to wire these up to a light & switch on the dashboard? Also.......Does the switch that operates the warning light have to be a push
& hold type switch (that makes momentary contact), or can it be an on/off rocker type switch? Appreciate any help.
flak monkey
| posted on 17/5/07 at 08:02 PM |
This should sort you out.
Most people use the handbrake switch as the test switch.
If you dont have the plug to fit the m/c you can find out which pin is which with a multimeter.
[Edited on 17/5/07 by flak monkey]
Sera
http://www.motosera.com
mattandmike
| posted on 17/5/07 at 08:13 PM |
Brake test switch.
Excellent, you are our wiring Guru!
Thanks very much. We don't have a handbrake switch, is that a must for SVA?
flak monkey
| posted on 17/5/07 at 08:20 PM |
Nope no requirement at all. All you need is a switch to check the brake warning light. Most people use the h/b one as its already there most of the
time.
One on the dash is fine. Usually just a momentary push-to-make switch will do.
Sera
Ketchup
| posted on 17/5/07 at 08:38 PM |
keep that avatar Flak
andyharding
| posted on 17/5/07 at 08:54 PM |
Better still, give us the www address you got it from
flak monkey
| posted on 17/5/07 at 09:06 PM |
None of which are work safe:
http://www.apneatic.com
http://www.myspace.com/apneatic
http://suicidegirls.com/
And I would suggest not wife or child safe either. And unsuitable for people who like their sex vanilla flavoured. I dont think i need say more.
Sera
