davrus
posted on 22/5/07 at 09:43 PM |
Missfire
Hi ya , following my previos thread Click If i disconect the vacum pipe from my
distributor it seem to run fine, connect it again and it pops and farts.
Any ideas with out spending lots of money.
Many thanks
Dave
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
flak monkey
posted on 22/5/07 at 09:45 PM |
Leave it disconnected and block the vacuum pipe off
Sounds like a timing issue rather than a fuelling issue then.
Sera
http://www.motosera.com
davrus
posted on 22/5/07 at 09:47 PM |
Do you think the timing could be out a nats dinkle?
flak monkey
posted on 23/5/07 at 06:59 AM |
Could be, have you got a strobe?
Sera
locoR1
posted on 23/5/07 at 07:20 AM |
Have you checked for play in the distributor shaft if it got play in it the dwell angle (points gap) will be all over the place!
I had the same problem with mine back in the old Xflow days.
Dave...........
Check out my CB500T Cafe Racer build diary
stevec
posted on 23/5/07 at 08:26 AM |
I had a similar thing years ago, it turned out that the wires between the distributer base plate and the out side were broken, When the vacuum advance
moved the base plate it caused the connection to fail. May be worth a look.
Steve.
posted on 23/5/07 at 11:27 AM |
Steve.
Had exactly the same fault on a mini years back, took a while to find that!
