r1_pete
posted on 25/5/07 at 07:52 AM |
Alternator
Anyone used a bike alternator on a car engine? I'm stuck for space and need an alternator about 100mm or so diameter. Will have to be converted
to poly v drive, any experiences?
Cheers.
Pete.
stevec
posted on 25/5/07 at 08:02 AM |
I have got a spare Kawasaki ZX10 bike Alternator and looking at it I would think the Front bearing may be a little small the take the load of a belt
drive,It is normally direct driven by a rubber cush drive, But there may be some types that are man enough.
Steve.
Agriv8
posted on 25/5/07 at 08:03 AM |
Have you had a look at the Kuboto alternator it is very small it might fit.
regards
Agriv8
fazerruss
posted on 25/5/07 at 08:28 AM |
alternator
If you can wait till after the week end I could have a look in my mums shed, there is at least 50 new or recon alternators of various types you could
have very cheap.![](/images//smilies/smile.gif)
posted on 25/5/07 at 08:53 AM |
think this one has coe up before.
bike alternators are fixed into the engine/geabox casing and driven via a gear so there is little loadinig on the bearings.
oh the otherhand car ones are attached to body and positoned to keep a drive belt in tension hence a fair bit of load on the bearings.
dunno how easy it would be to adapt a bike one; you would also need to work out the gearing i.e. puylley diameters.
r1_pete
posted on 25/5/07 at 10:27 AM |
have very cheap.
Yes I'm in no rush, collecting parts at the moment, and making sure I have all key components before a trial fit....
Cheers.
Pete.
Humbug
posted on 25/5/07 at 10:56 AM |
??? My Rover K-series has the alternator fixed to the engine block. My previous kit car had a Pinto, and the alterntor was fixed directly to the
engine on that too.
MonkeyHunter
posted on 25/5/07 at 11:31 AM |
fazerruss You have U2U.
Scott.
have very cheap.
[Edited on 25/5/07 by MonkeyHunter]
