Author: Subject: wiring up lights savage switch
mkblade
posted on 3/6/07 at 10:31 PM Reply With Quote
after spening hours today trying to work out how to do this i gave up. im hoping someone can give me some more info on how to wire up the lights hazards ect.
i got the h/brake warning light working i also got the side light working but thats it.
im using a premer wiring loom and origaly had the seirra switches which i wired up no problem,now i have done away with the seirra stuff and got savage switches.
ive wired up the side lights like this
terminal 1 red wire (batt pos)
terminal 2 slate wire (to fuse box)
this works ok,not sure if its right ?
i thoght i could just put a ign live to each switch ie term 1 then say bron/white (main beam wire ) to terminal 2 but it doesnt work not sure if the switch needs a earth as the side light didnt seem to need one
sorry if its long winded
cheers simon
p.s the switches i have are side light,dip beam,high beam hazard switch..
do i need another switch for the high beam flash ??
thanks simon
bigrich
posted on 3/6/07 at 10:51 PM Reply With Quote
arnt some sierra switches switched earth rather than switched voltage, maybe the main beam etc needs earths not ignition supplys as i would pressume you are controling relays not the lights directly.
Rich
