Author: Subject: temp sensor wiring question
zxrlocost
posted on 10/6/07 at 07:54 PM Reply With Quote
hi
my koso dash has 2 wires going into the temp sensor
however my fireblade temp sensor wont budge and is going to round off its been there for 12 years so I may aswell use it for now if I can
but the fireblade temp sensor only has 1 wire
whats the two wires for as opossed to 1
ta chris
big_wasa
posted on 10/6/07 at 08:18 PM Reply With Quote
one of the two will be an earth. The temp housing willl be alloy on the blade, giving you the earth.
rusty
posted on 11/6/07 at 11:17 AM Reply With Quote
The promlem with using the factory sender is that the gauge may read wrong as the gauge will not be calibrated to work with the factory sender.
twybrow
posted on 11/6/07 at 11:35 AM Reply With Quote
Chris can you keep us updated as to how this works out? I want to do this on my engine, but I am worried about the sclae. My gauges have a 100ohm resistor in series going to the gauges. I was thinking I could just plug the Koso straight in, but maybe not...
