adrian
posted on 10/6/07 at 09:05 PM |
telemetrix speedo wiring
hi can anyone help
im trying to wire my telemetrix speedo with magnet sensor and 4 magnets, the instructions contradict what is on the website ,
cant get a reading
not sure if its wired correctly?
indykid
posted on 10/6/07 at 09:14 PM |
have you connected the 12v pull up red wire?
i had the same problem, which was discussed here
hth
tom
adrian
posted on 10/6/07 at 09:18 PM |
hi matey,
just read through your link , i have one side of sensor to earth and other wire to blue /red on speedo
dont understand what a 12v pull up is?
can you help!!
thanks
indykid
posted on 10/6/07 at 09:28 PM |
it's a red wire in the loom on the back of the gauge. just connect it to a 12v switched supply.
i don't have the diagrams to hand or i'd tell you pin numbers and suchlike.
let me know if it's still clear as mud and i'll see what else i can find out for you
tom
adrian
posted on 10/6/07 at 09:32 PM |
thanks matey, i'll have a look tommoro!
adrian
posted on 11/6/07 at 08:45 PM |
does anyone know which wires to connect on the back (pin no.s)?
