Author: Subject: Wiring diagram needed
davrus
posted on 13/6/07 at 06:07 PM Reply With Quote
Hi ya
Iam looking for a wiring diagram for the ignition module from and early fiest poss mid 80s.
It is a 3 pin module.
I dont have the plug eaither so i need to know what terminal goes where.
Also if you have a complete diagram of the electronic ignition system then it would be much appreciated as the coil needs wiring as well.
Many thanks
Dave
[Edited on 13-6-07 by davrus]
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
posted on 14/6/07 at 07:03 PM Reply With Quote
Not sure if this helps, not even sure if it's even near the right answer, but here goes:
This article explains how to fit the Valencia dizzy and ign module into a crossflow. Unfortunately it only talks about the wire colours that lead out of the plug!
So the other half of my possibly-not-the-right-answer is - you'll find life much easier if you get the right plug!
posted on 14/6/07 at 07:13 PM Reply With Quote
Dave , try a search for valencia distributor wires by johnemms. Must find out how to put in link!
