Author: Subject: Speedo Sensor
The Baron
posted on 17/6/07 at 12:26 PM Reply With Quote
Speedo Sensor
Does any one know of a electronic speedo sensor which runs on the end of a speedo cable?
Is the proper name of these, 'Hall effect sensors'?
Cheers in advance,
The Baron
turbodisplay
posted on 17/6/07 at 03:28 PM Reply With Quote
Yes hall effect.
Will need to be powered, normal voltage to power is 5v or 12v types (12v for car normally).
Digital types are the normal type (on/ off according to proximity of the tooth wheel) you will use.
Darren
mark chandler
posted on 17/6/07 at 07:29 PM Reply With Quote
Later classic range rovers, 3.9 so after around 'H' plate had standard gearbox drive, 6 inches of speedo cable into a box that bolted inside the chassis which then provided the electronic speedo drive.
Loads of people break these on Ebay so you should be able to get one for pennies.
Regards Mark
kenton
posted on 17/6/07 at 08:32 PM Reply With Quote
hi
rally design do them, £21 to £28.
kenton
FEZ1025
posted on 22/6/07 at 09:29 AM Reply With Quote
Originally posted by kenton
hi
kenton
grpdirect.co.uk also do them I've just fitted a Terratrip TERT006 to an Acewell, simple to fit & has sorted out the inaccuracies.
Alan./..
