flak monkey
| posted on 22/6/07 at 04:34 PM |
AIM MXL Digidash
Look what I have just got my grubby mitts on.
An AIM MXL pro 05 datalogging dash with lots of toys. I need to generate all the cables for it, but thankfully I dont think that will be a problem!
[Edited on 25/6/07 by flak monkey]
Sera
http://www.motosera.com
nitram38
| posted on 22/6/07 at 04:37 PM |
You lucky Bas................
flak monkey
| posted on 22/6/07 at 04:39 PM |
http://www.aimsports.com/products/mxl-pro/features.html
First question, anyone know where I can find 37 and 22 way deutsch connectors?
Sera
flak monkey
| posted on 22/6/07 at 05:23 PM |
Best I can ascertain the connectors are 37 way and 22 way bayonet locking MIL spec affairs.
Had a look on the RS site and needless to say they are a touch pricey, but I am not entirely sure I have the right ones. The pin layouts look the
same, but theres Key N and Key A ones, and I dont understand the difference
22 Pin key N
22 pin key A
37 pin key N
37 pin key A
Any ideas?
Sera
Confused but excited.
| posted on 22/6/07 at 05:37 PM |
I think you will find the difference is in the pins. One will have female pins (hollow), as in a flying socket. So that they make a pair of
connectors.
flak monkey
| posted on 22/6/07 at 07:02 PM |
Apparently its to do with the ribs on the plug which make sure you put them in the right way. Mine are N type apparently.
Sera
matt.c
| posted on 22/6/07 at 08:49 PM |
lucky fecker!!! Thats the bo**ocks mate!!!! you dont really need that do you
I want a student loan!!!
[Edited on 22/6/07 by matt.c]
humphfury
| posted on 22/6/07 at 09:03 PM |
Try www.deutschuk.com for AS Double Density connectors. If the connectors have a red colour band then they are N keyway (the most common).
Humphfury
flak monkey
| posted on 22/6/07 at 09:42 PM |
Humphfury
Thanks for that, they do have a red colour band, and I have emailed deutsch for some info with the numbers on the connectors. Hopefully they can sort
me out with the necessary bits.
No Matt you cant have it . Not even sure when I will get around to swapping them over. When I sort the new dash after SVA looks like a probability
if I can get this one programmed and working (I dont have the USB lead a the mo)
Sera
bigrich
| posted on 22/6/07 at 10:18 PM |
thats almost as sexy as the lady in your avatar
humphfury
| posted on 23/6/07 at 03:30 PM |
Are there are any numbers on the connectors as I might know someone who would be able to identify the mating part.
Humphfury
flak monkey
| posted on 23/6/07 at 03:40 PM |
Humphfury
Thanks, dont suppose you know where I can get them from?
What I need is a Deutsch AS614-35PN or Souriau 8STA6-14-35PN connector. Have emailed both Deutsch and Souriau in the hope one of them will be able to
supply one of the connectors as I cannot find them from either RS or Farnell and I dont know where else to look. The closest I have found is the ones
on the RS website but they are size 15 housings and I need size 14.
Sera
flak monkey
| posted on 25/6/07 at 04:14 PM |
Sorted, got put in touch with Servo Interconnect by Deutsch. Now I need to find the money! Mil Spec connectors aint cheap...
Sera
humphfury
| posted on 25/6/07 at 07:39 PM |
Yes, that's the company that my contact suggested.
He also mentioned 2nd mortgage!!!!!!!!
Humphfury
