PeterW
posted on 9/7/07 at 07:11 PM |
Toggle switches and SVA
Evening all....
Building a Tiger Cat, and I've got a problem with the switches. The ones Tiger supply are a bit odd, with a D shaped connector with 2 or more
pins. I can't find a decent supplier online for these and I want to replace them.
However....
I don't want to spend £150 on Savage switches and thought about using the same idea that is on the new Mini like this...
So can anyone see a problem with the SVA...? Ideally, I want to use a switch similar to these...
ANyone see a problem...? Thinking of making sure the switch tips can't be touched by the SVA testers magic ball...
Pete
roadrunner
posted on 9/7/07 at 07:16 PM |
If you do it like the mini one's, i cant see you having any problems, just make sure , what you use to shroude the switches has a decent radius.
iank
posted on 9/7/07 at 07:20 PM |
Spyker do the same trick
http://www.locostbuilders.co.uk/viewthread.php?tid=36859
Personally I think it would pass fine (BMW did the guard for the same reason), but I'm not a tester
Anonymous
PeterW
posted on 9/7/07 at 07:36 PM |
Cheers for the comments
I planned to look at a slightly different setup, using bars above and below the switches, rather than in between each one.
Think B&Q stainless steel cupboard handles....
Anyone know where you can get a SPST momentary toggle switch..?
Pete
darrens
posted on 9/7/07 at 08:11 PM |
Pete
Either of These anygood
http://docs-europe.electrocomponents.com/webdocs/0066/0900766b800663ed.pdf
(these are SPST I believe)
http://docs-europe.electrocomponents.com/webdocs/01b9/0900766b801b9df7.pdf
think RS might stock them.
[Edited on 9/7/07 by darrens]
rusty
posted on 9/7/07 at 08:17 PM |
I used some of these
Switches
ChrisGamlin
posted on 13/7/07 at 08:06 PM |
Wouldnt it be just as easy to do an "SVA dash" to get you through the test, then another one to put it all how you really want it?
