Author: Subject: Lights - where's the problem?!
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
Building: Bought (yeah, I know it's cheating) Sylva Pho
posted on 18/7/07 at 08:45 PM Reply With Quote
I'm hoping that someone may be able to answer my question fairly easily. A problem has appeared with my lights in the past week.
With no lights on or just side lights on, all indicators and lights work fine. However, when dipped or full beam are on, the left front headlight isn't on properly, and the left side and rear indicators are on permanently. Indicating left does nothing, while indicating right works fine (albeit leaving the left side and rear indicators on).
I expect (hope!) it's something very straightforward, and have had a quick go at cleaning up the connections without taking much apart, but thought I'd ask here to see if anyone could suggest where to target my efforts.
Thanks for your help.
Sam
minitici
posted on 18/7/07 at 08:47 PM Reply With Quote
Sounds like an earthing problem (on left hand headlight).
[Edited on 18/7/07 by minitici]
davrus
posted on 18/7/07 at 08:48 PM Reply With Quote
Bad earth some where?
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
blakep82
posted on 18/7/07 at 08:51 PM Reply With Quote
yeah, dodgy earths cause all manner of funky problems
________________________
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 18/7/07 at 08:56 PM Reply With Quote
Sounds like a pretty unanimous answer. Will have a play tomorrow and hopefully sort it out.
Thank you.
RazMan
posted on 18/7/07 at 09:49 PM Reply With Quote
It does sound like an earth problem - maybe a bit of corrosion on a terminal somewhere. Also worth checking that you havent got a short between circuits (ie sidelights to headlights or indicator) Just use a continuity checker to buzz out each circuit.
Raz
