Author: Subject: ZX9R Carbs (Type E) TPS Wire Colours
andyace
posted on 21/7/07 at 06:30 PM Reply With Quote
Does anyone know which wires are which on the ZX9R Type E TPS.
I have Black, Blue and Yellow.
Many thanks.
posted on 21/7/07 at 06:50 PM Reply With Quote
Black/blue, Yellow/white and a solid blue according to my diagram. They go straight to the IC on a dedicated plug.
Ah, you want the wires for a megajolt or something. Blacks seem to be earth and yellows ignition controlled lives so the blue must be to the sensor.
[Edited on 21/7/07 by Peteff]
andyace
posted on 21/7/07 at 07:09 PM Reply With Quote
Deffo black, blue and yellow and they do go to a plug, however these are going on a pinot engine to a megajolt, but I don't know whaich wire is which.
Whats the best way to work it all out ?
tim windmill
posted on 22/7/07 at 06:46 AM Reply With Quote
as long as you get the earth right just connect either way round and then check in the megajolt software the green bar should go up when you press the throttle if it goes down you have got the wires the wrong way round. I had megajlt on a pinto with zx9 carbs and they worked a treat.
