Author: Subject: Wheel Studs
oldmanmille
posted on 22/7/07 at 07:37 PM Reply With Quote
Wheel Studs
I need to extend the wheel studs - does anyone know if they cab be purchased, and from whom? or is it a matter of just getting some machined?
Ford hubs by the way!
COREdevelopments
posted on 22/7/07 at 07:43 PM Reply With Quote
believe rallydesign do extended wheelstuds, along with some local motorfactors. also ebay should have some. are you using spacers?
rob
DavidM
posted on 22/7/07 at 07:45 PM Reply With Quote
Rally Design supply longer studs.
http://www.rallydesign.co.uk/catalog/index.php?cPath=731_735
theohighland
posted on 22/7/07 at 07:48 PM Reply With Quote
i got mine on ebay, worked out at about £1 each with postage.
i know Rally design do stud and spacer sets as well
Theo
oldmanmille
posted on 22/7/07 at 07:54 PM Reply With Quote
Cheers guys...I will be using spacers ont he back but not sure about front yet
Thanks again...
COREdevelopments
posted on 22/7/07 at 07:58 PM Reply With Quote
if i were you i would use a good set of hubcentric spacers and not the cast crap you can buy.
hth
rob
