ditchlewis
posted on 25/7/07 at 08:29 AM |
Alternator Belt Tensioning?
Hi Guys
In a similar vain to another post to day, I have a problem with my alternator belt.
I took Mk’s advice and mounted the alternator off the water pump. Ok so far the problem has always been that there is little adjustment and getting
the belt tight is very difficult and depends on the sliding mount at the top for structural support. To change the belt requires the alternator to be
removed a B~~~~r of a job.
Has any one put a belt tension wheel on before?
How does the pinto cam belt tensioner work? Could it be mounted some how and used to tension the alternator belt.
Suggestions please as the squeal is really P~~~~~g me off.
regards
Ditch
RazMan
| posted on 25/7/07 at 08:39 AM |
How about this sort of thing?
[Edited on 25-7-07 by RazMan]
Raz
ditchlewis
| posted on 25/7/07 at 11:16 AM |
cool
where do you get one?
alternatively where do you get the threaded tube? i know where i can get rose joints.
Ditch
RazMan
| posted on 25/7/07 at 11:24 AM |
http://www.sbdev.co.uk/Set_Up_Information.htm
I'm thinking of getting one simply because it looks like a well engineered solution to a common problem.
Raz
ditchlewis
| posted on 25/7/07 at 02:02 PM |
thanks for that.
looks like about 50 quid if i'm reading the price list correctly, for full mounting kit. wonder if they sell the top only? will have to call.
also thought of this mounted on the top arm some how to provide tension.
ditch   Image deleted by owner
40inches
| posted on 25/7/07 at 03:13 PM |
Try Nick Skidmore,fast and reasonable prices.
bob
| posted on 25/7/07 at 03:27 PM |
I didnt bolt onto the water pump at all, decided to use the pivot on the cobbled together alt bracket and make up a slider on the top bolted to a
spare M8 thread on the pinto head.
Unfortunatly i have not kept any of the old parts when i did the engine change.
