Author: Subject: Savage horn wiring?
nib1980
posted on 26/7/07 at 05:50 AM Reply With Quote
Savage horn wiring?
Hi All,
tried to wire the horn up last night using a savage switch and i couldn't get it to work, I'm not normally to bad with electrics, I cennected the +12v to pin 1, the switch and push had no effect, only permantely sounded on pin 3 , and nothing on pin 2. and ideas?
many thanks
Howlor
posted on 26/7/07 at 06:07 AM Reply With Quote
Isn't it a switched earth. You need to earth one side of the savage and then connect the other to the horn.
Avoneer
posted on 26/7/07 at 06:21 AM Reply With Quote
+12v in on pin 1.
When you put the switch on, +12v comes out on pin 2 on the same side.
Simple.
Pat...
nib1980
posted on 26/7/07 at 06:30 AM Reply With Quote
Originally posted by Avoneer
+12v in on pin 1.
Simple.
Pat...
i was sure i'd tried that, but i'll have another go tonight.....???
RazMan
posted on 26/7/07 at 07:08 AM Reply With Quote
Does this help?
[img][/img]
Raz
Howlor
posted on 26/7/07 at 07:32 AM Reply With Quote
Try swapping the wires round on the horn as I know this worked for me.
DarrenW
posted on 26/7/07 at 09:18 AM Reply With Quote
The confusing bit with savage switches is that they are basically 2 switches in one. In most applications you just use one set of terminals.
